| RE: Picture size limits by Doug_s |
| A little more data:all pic are uploaded from the same place etc. all display locally, no errors when... |
| Morning, Thanks for the suggestion - a little different to this. This is a simple senario I add a ... |
| RE: query regarding page options by kaustav_kar |
| Thanks for your reply.Could you please let me know from where I can get the OWS module?Thanks |
| RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by leesykes |
| Hello,Yes that's the only method I can see to make it work.Create a Tabs page - give edit permission... |
| RE: Uploading an MP3 file to my website by leesykes |
| If you are going to be uploading a lot of large MP3 files you may find it is best to use FTP, make a... |
| RE: Custom Textbox Size by leesykes |
| I can't see an easy way to do this with a standard text box, I've tried CSS styling the id and can't... |
| RE: query regarding page options by leesykes |
| hello,If you do not wish your visitors to login, then I think the only other option will be to use c... |
| Localizing Skins and css dynamically based on language selected by sadabahar83 |
| Hi,
I want to dynamically assign a skin and CSS based on the language selected.
Different pag... |
| Recomended DNN version? by lolorn |
| What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as st... |
| Hi,My site will have two Home pages, one for a new visitor and one for a returning visitor. Is the... |
| RE: Plz Help. Page_Load_Exception by zaidkhan |
| URL of My website is www.pafkiet.edu.pk |
| Few new skins by Rozo |
| Skins for DNN and other CMS.
www.stelg.com |
| RE: Plz Help. Page_Load_Exception by jncraig |
| Can you provide a URL? |
| RE: Custom Textbox Size by jncraig |
| For the second part, you can switch the editor to source mode and enter unstyled text. For the fi... |
| RE: Picture size limits by jncraig |
| The little red x's generally mean that the link to the image is broken. My guess is that you have a... |
| RE: Uploading an MP3 file to my website by jncraig |
| web.config is in the root directory of your DotNetNuke installation. ALWAYS (!!) make a backup copy... |
| RE: Customizing registration page by kana |
| Ok, thank You for answers.
I'll try to make it with OWS.
Marek |
| I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt... |
| RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst |
| Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and... |
| Ealo Tab Localization help by sadabahar83 |
| hi,
I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider.
menu is wor... |
