Subject: error: registration is not available
cipher2079
01 Oct 2006 12:32 PM
Hi lee,
I just started working on issue 13 and got an error when trying to register a new
user. i tried finding an answer for this but could not find though I will keep, hopefully you can help me.
Forums > Users Lounge > Everything Else > error: registration is not available
