Subject: Were can I find the text for each of the pages in vortex
cipher2079
13 Aug 2006 8:39 AM
Hi lee
I am currently working on "How to build a website in DotNetNuke" Styling and formatting (part 2) – Text/HTML module and FCKEditor
My question is Were can I find the text for each of the pages in a word document
can you please give me the direct link if possible
16 Aug 2006 3:39 AM
I don't include the text with the videos, it just comes with the code. If you wish to add test text to a web page while you are designing it, I use:
http://www.lorem-ipsum.info/generator3
Forums > Users Lounge > Everything Else > Were can I find the text for each of the pages in vortex
