Subject: DNN Creative News Feed not Working?
ollep
14 Oct 2008 10:41 PM
Hi Again.
Now I’m on to the News Feed Module and RSS Feed.
Is the News Feeds 04.00.00 quite different from the one used in the Tutorials?
Or am I on the wrong track somewhere?
I have managed to get one feed working
http://feeds.feedburner.com/EntrepreneursJourney
But all other including Australia News and DNN Creative feeds gives me download error?
Feed 'http://www.abc.net.au/newsradio/rss/TOURISTINFORMATION.xml' could not be loaded. Error: Download error
Feed 'http://www.dnncreative.com/Articles/tabid/99/articleType/CategoryView/categoryId/36/Articles-RSS.aspx' could not be loaded. Error: Download error
ollep
15 Oct 2008 3:16 AM
Hi Again.
Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation?
And that it is as a Module setting option only, rather than individual feed settings?
I also found the files: Default, Ticker and VScroll.xsl??
Could I also assume that the RSS 0.91 is gone today, leaving us with 2.0 – or maybe later version?
The below is features I can’t find in my 4.0 News Feed Module?
1.       Under News Feed Style Sheet, select “Link Type: File (A File On Your Site)”
2.       Click on Upload New File
3.       Upload the new XSL file
4.       Click on Update
And the following is the News Feed 4.0 Default.xsl.
  <xsl:for-each select="channel/item[position()<=$ItemsToShow or $ItemsToShow<1]">
   <p class="DNN_News_ItemLink">
    <a href="{link}" target="_main">
     <xsl:value-of select="title"/>
    a>
   p>
   <xsl:if test="$ShowItemDate='true'">
    <p class="DNN_News_ItemDate">
     <xsl:value-of select="pubDate"/>
    p>
   xsl:if>
   <xsl:if test="$ShowItemDetails='true'">
    <p class="DNN_News_ItemDetails">
     <xsl:value-of select="description" disable-output-escaping="yes"/>
    p>
   xsl:if>
ollep
15 Oct 2008 6:16 AM
One last bit before bedtime.
With the below section in the “.xsl” I managed to get it down to title and date only, and also get an empty line in between.
I tried “false” here to remove the content but it had no result:
   <xsl:if test="$ShowItemDetails='false'">
So I commented out the entire section.
As I mention, I have only the “Module Option” to choose “.xsl” file here in 4.0.
So, how do I select the settings for several different feeds?
If I have 5 feeds and want to show 5 items from each feed?
Good Night.
  <xsl:for-each select="channel/item[position()< 6]">
    a>
   p>
      <br />
      <br />
    p>
   xsl:if>
mgordon
15 Oct 2008 10:27 AM
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It has been coded so rigorously to adhere to web 2.0 standards that many, many news feeds don't have their code to live up to this modules standards.  I know that a new version is in Beta to take care of most of the problems that everyone is experiencing, however, until that version comes out, everybody who uses this version of the module is FUBAR.
Check out dotnetnuke.com and see how many people are complaining about this version of the module.  It's mind-boggling that it's taking this long to get a new version out there.
Again, IMHO.
Mark Gordon
Webmonkey
17 Oct 2008 8:58 AM
 If the core DNN News feed isn't working very well at the moment, I would look at Orizonti NukeFeeds module, its much better and easy to configure and setup multiple feeds
ollep
03 Nov 2008 3:07 AM
Thanks Lee
Found that I bought Orizonti already last year - and forgot it.
I'ts now installed and work fine!!!
Cheers....
05 Nov 2008 8:15 AM
bargain!
Forums > Users Lounge > Everything Else > DNN Creative News Feed not Working?
