Subject: Register Link Inactive
Albatroz2000
09 Oct 2008 11:14 AM
I have two sites with DNN versions 4.5.5 and 4.8.4.  On both sites I find that when we click the REGISTER links, they are inactive.  It does not take you to the registration page.  Also, after you login the Display Name (in place of REGISTER after you login) link does not work either to allow you to edit your profile.
The site is public.  I have a button within the TEXT/HTML portion with a registration link that works, but I need the REGISTER link that comes with the system to work at least for users to be able to edit their profile.
Can someone help me please?  Thanks.
09 Oct 2008 1:41 PM
Have you perhaps specified a custom registration page?
Albatroz2000
09 Oct 2008 2:07 PM
Thanks for the quick response Joe. What I have is the homepage with a button that allows the users to click and register. I do not have a custom registration page. You can view the page at www.aec-university.com (If this is allowed in the forum).
09 Oct 2008 5:56 PM
Well, I clicked on your link and then clicked the "Register Now" button. That took me to the Registration Page. The register link on your login page doesn't work. Hard to tell without digging deeper into the site.
It looks like you've defined a custom login page, but I don't see why the Registration link on it doesn't work.
Forums > Users Lounge > Everything Else > Register Link Inactive
