Subject: Menu bar and CSS
wsiwpg
03 Oct 2008 2:57 PM
Hi There,
I have created a vertical menu bar and am positioning where it is on the pg with CSS. I have the menu placed on a background and again positioned the background with CSS. I have used position:relative; in the css file to position it where I need it on the page. Now when I hover over the links, whenever I have subpages those pop out somewhere else on the page, no where near the actual menu. And to make matters worse, I have 2 other items on the page positioned with the relative property and so some of the sub pages go under one of the other items and I can't even get to the link to click on it now. Is there a way to move the sub page links up to beside the menu where they should be and to appear on top of any items located close by? Sorry if this is a bit confusing. Any help would be greatly appreciated.
03 Oct 2008 5:04 PM
can you attach your skin file or give us a link?
wsiwpg
03 Oct 2008 5:14 PM
I have attached the skin to here. The site is: brownandrutherford.com.previewyoursites.com and I have applied the skin to the Test page.
Attachment: 110314941671.zip
wsiwpg
08 Oct 2008 1:03 PM
Just wondering if anyone has figured out how to solve my problem.
10 Oct 2008 9:14 AM
ok, I'm back from openforce, I can't see any sub menus on the test page, can you add some sub menus so I can see this in action, thanks,
wsiwpg
15 Oct 2008 12:49 PM
Ok, i have now added some sub pages to the site. Can you please go look at it now.
Thanks.
17 Oct 2008 9:14 AM
The first problem is related to the relative property, the method you have used causes each sub menu to also use the relative position which is why each sub menu is positioned further away.
Next problem was the large width for the menu, I set the background to #fff so that I could see the size of the main menu + could then find a suitable width of 150px.
Next problem is the sub menus display underneath the flash - this is a common problem and I do not know of a solution, but if you look, I moved the flash further to the right so that you can see the sub menus.
These changes will not be suitable for your skin, but at least from here you will be able to see the menu working and then see what changes you need to make from there.
.menu_style
    float:left;
    width:150px;
    height:370px;
    z-index:3;
    background-color:#fff;
.flash_style
    float:right;
    width:785px;
    height:300px;
    background:#603311;
    position:relative;
    z-index:2;
    left:-10px;
Forums > Users Lounge > Everything Else > Menu bar and CSS
