Subject: how to separate out 2-applications under one folder
ptelang
26 Sep 2008 8:36 AM
We have created two portals under a folder DNN namly abc and xyz under domain www.testdnn.com ; we access abc as default and xyz as www.testdnn.com/xyz
Now we want to separate out both and put them under abc.com and xyz.com
We created separate domains in iis and assigned respective physical directory path; but the problem is its not showing xyz in xyz.com; it keeps showing abc site only ; how to solve the problem
Thanks Prashant
26 Sep 2008 9:59 AM
Have you changed your portal alias for www.testdnn.com/xyz to www.xyz.com ?
You can check your portal aliases in host menu / portals
ptelang
26 Sep 2008 11:44 AM
Hello
Thanks for the response
Yes we have but it is still showing abc
any other suggestion
29 Sep 2008 10:55 AM
have you also removed the old url of: www.testdnn.com/xyz from the portal alias?
other than that I'm not sure what else to suggest, anyone else?
Forums > Users Lounge > Everything Else > how to separate out 2-applications under one folder
