Subject: Flash in FireFox - Joe?
ollep
25 Sep 2008 3:33 PM
Hi Joe.
You said that you where running your Flash – Movies in FireFox?
I just reinstalled 2 Flash Movies on this page. One basic image display and an animated banner ad in the bottom.
Non of them shows up in my FireFox browser???  (Updated as I Opened it this morning.)
http://www.planetmudgeeraba.com  -  Image Display.
http://www.planetmudgeeraba.com/ImageDisplay/tabid/198/Default.aspx
I have no problem with them in IE 6 or IE 7.
Also, can I put an “Alt Text” in the Flash Movies? Could be good if they doesn’t show up somewhere.
Cheers Guys.
Forums > Users Lounge > Everything Else > Flash in FireFox - Joe?
