Subject: User Registration functionality
tallorder49
25 Sep 2008 9:33 AM
I am building an ecommerce site and I want to make it quick and easy for shoppers to register quickly (so just minimal information requested).   However, I also need a Members registration where we want to ask for their interests (mandatory).
Ideally, it would be a quick registration and those that ticked the box "I'd like to be a member" would then be asked more questions next time they logged on (I validation mode).
Can anyone tell me how I could offer this sort of functionality in DNN 4.8?
25 Sep 2008 10:32 PM
Data Springs' Dynamic Registration and Dynamic Login are two modules that will let you create a very customized Registration and/or Login process.
Forums > Users Lounge > Everything Else > User Registration functionality
