Subject: 4.8.2 redirect issue
uds_dnn
19 Sep 2008 10:37 AM
I am trying to redirect to a customer build commerce page off a custom login page modified within the DNN login module.
I have read that the redirect after login has issues and I too have not had any luck.
Would anyone have a solution for this issue ?
A) is there a codeing solution and where ould it go.
b) is there a patch or upgrade
C) Hhy have a option in the system if If it is Broke!
What are all the consideration when redirecting (portal settings , User setting, file settings, module settings)
thanks
19 Sep 2008 11:40 PM
You could try upgrading to 4.9.0.
When you say "modified" do you mean that you have modified the DotNetNuke login module?
Forums > Users Lounge > Everything Else > 4.8.2 redirect issue
