Subject: Align Images in DNN 04.09
ollep
18 Sep 2008 8:13 PM
Why can't I align centre on content pane images?
DNN 04 09 00
Andreas 09 Skin
Text / HTML module:
Below I double up the "align=centre" but I tried all different variations.
The image insist on sitting to the left. ?????
HELP Please.
Olle...
19 Sep 2008 7:54 AM
While editing in the Text/HTML module, higlight the image and then click the centering button in the toolbar.
ollep
20 Sep 2008 7:47 PM
Thanks Joe
Yea the question might appear stupidly simple.
I do normally align images using the editor toolbars, but this time it had no effect.
I then change the editors setting:
And tried “div” tags instead:
and
Nothing will center an image properly in the content pane, the right pane center images normally.
www.mudgeerabahilltons.com
I eventually found this class in “skin.css”:
#content .Normal img,#contentalt .Normal img
/*specified it into the Normal class, otherwise it adds space to images such as the help '?'
when clicking on login */
border:1px solid #b0b0b0;
float:left;
margin:5px 15px 6px;
padding:5px;
Try widening the window, you will see the image dropping below the container seemingly down to the footer line.
Cheers
Olle…
21 Sep 2008 8:37 AM
Yes, that class in the skin.css file will "float" images to the left.
Forums > Users Lounge > Everything Else > Align Images in DNN 04.09
