Subject: A bit od Container SEO?
ollep
16 Sep 2008 10:27 PM
Hi Lee:
What does this mean in regards to SEO?
When using these containers, the header tags are placed around the title of the module.
I normally leave the container heading blank and write a heading in the text, including the H1 tags.
Am I better off using the container header?
Should I always aim to have the keywords in there?
If I use the container header:
Can I still – or should I – still use H1 and H2 tags in the content?
Just some thoughts:
Thanks for any advice…
Olle..
www.planetmudgeeraba.com
24 Sep 2008 4:59 AM
If you use one of the containers that have header tags around the content title, but don't enter any content for the title, you will end up with < h1 > < /h1 > in the source code.
if you do not wish to use the container titles then use the transparent container.
In terms of SEO it will not make any difference whether you add the title into the container or into your main content, as long as you add header tags around your titles the search engines will not notice any difference.
If you use the container with the header tags (which is what I do) - you should still use header tags in the content for any further titles.
Basically any text which is a title should have a header tag around it, whether it is a h1, h2, h3, h4, h5, or h6.
have a read of this:
Semantic Code and Header Tags in DotNetNuke Skins
ollep
24 Sep 2008 6:40 AM
Thanks.
That was good and helpful.
Olle....
Forums > Users Lounge > Everything Else > A bit od Container SEO?
