Subject: Database error
derpir
05 Sep 2008 10:52 AM
Hello
I am trying to transfer my website from localhost to my live site. After attaching the DB and changing the web config I got an error when I debugged in VS, I got this...
Login failed for user 'felpal. The user is not associated with a trusted SQL Server connection.
whats wrong?
how can I fix it?
please help
best regards
05 Sep 2008 10:57 AM
have a look here
derpir
05 Sep 2008 11:28 AM
Hello
thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Server express 2005, In the post were craig bescribes how he did, I wonder if its different in the SQL Server express 2005?
I just can't find where to change it...sorry
regards
05 Sep 2008 11:33 AM
I just checked and it does have it:
Right click on the SQL server node - this is the node with the green arrow on it
Properties
Security
derpir
05 Sep 2008 11:40 AM
You put me on the right track there. Turns out that I had server authentication set to
'Windows Authentication' mode rather than the required
'SQL Server and Windows Authentication mode
When craig says change to SQL Server and Windows Authentication mode
the trouble is that I can't find were to change this even though Craig desbribes it very well,
The only thing is that I can only find windows authentication mode but not the 'SQL Server and Windows Authentication mode' as Craig refers to. they are seperated not together, I can only chose one of them not them together?
Thats why I am asking if there could be a difference between 2005 and 2008 visually?
best regards
derpir
05 Sep 2008 11:46 AM
nailed it!!!
but how do I restart with the configuration tool?
regards
//newbie
05 Sep 2008 11:50 AM
go to programs / microsoft sql server 2005 / configuration tools / SQL server configuration manager.
Click on SQL Server 2005 Services
Right click on SQL Server (SQL Express) (with the green arrow)
Select Restart
derpir
05 Sep 2008 12:00 PM
Yeees!!!
thank so much Lee!!!
I will continue this by looking at video nr 3 on how to transfer from localhost to live site.
thank you!
