Subject: Keep Testing Skins
ollep
05 Sep 2008 12:28 AM
Thanks for your reply Yesterday Lee.
I will do a new upload and see if I can get the template working.
I’m playing with some different skins, causing problems for myself.
(Believe I slowly get the hang of it, and can sort out the CSS now.)
When I upload several skins on the same hosting (for testing in different portals) they seems to integrate into one “skin” folder.
Also the containers sometimes have the same name?
Am I suppose to rename everything, or at least the “skin.zip” file before uploading?
I want to test Summer Breeze and Zenlike at the same hosting as the 2 below.
Cheers
Olle….
Here’s a version of the “Curiously Green”
http://www.goldcoastwebwiz.com/dotnetnuke/grape
And this is Lazy Days
http://www.goldcoastwebwiz.com/susana
05 Sep 2008 4:15 AM
For the downloads from DNN Creative you should not have to rename.
When you upload the skin zip it should be named:
curiously_green.zip
zenlike.zip
etc.
you just upload that file using the install skin method
Inside the zip are 2 zips named: skins and containers
As long as you leave those zips inside the curiously_green.zip  for example, it will name the skin and container files correctly.
If you are installing your own files and just have a container or a skin zip (without the package zip) then you need to name those zips with the skin / container name you require
ollep
07 Sep 2008 9:00 PM
Hi Lee – and Joe
I’m Using DNN 4.5.5
I just installed Summer Breeze Skin and Template, and attempted to create a portal with the Summer Breeze template.
Still get the error that it is not a Portal Template.
In the Skin.css you use Inhered
Doesn’t seem to be a #header class in the summer-breeze skin.
So where do I position the header image?
ollep
07 Sep 2008 11:08 PM
Some details re Logo possition:
HTML:
<div class="header">
<p>[LOGO]p>div>
Found possitioning in "index_logo.css"
/* align logo to left side rather than center */
.header {
text-align: left;  }
/* place the logo in the blue central area */
.header p {
margin: 0 auto;
width: 590px;   }
/* move logo into position */
#dnn_dnnLOGO_imgLogo {
position: relative;
top:45px;   }
Why having this little bit in a seperate "css"?
URL:  www.goldcoastwebwiz.com/dotnetnuke/q1
Cheers
ollep
08 Sep 2008 1:20 AM
Slowly sorting it out.
The logo position is OK.
But I used negative margins to get it close to alignment with the content.
It doesn’t seem right?
Another one:
Why so wide images for the background?
Summer Breeze is 1024 wide.
Curiously Green is 1670 wide
Cheers
Olle….
position: absolute;
margin: 2px 0px 2px -12px;
Forums > Users Lounge > Everything Else > Keep Testing Skins
