Subject: My Server's Event Viewer
mgordon
28 Aug 2008 8:25 AM
Help!  Not sure what's going on.  Every ten minutes, on the dot, I am getting an Information log in my Appllication Event Viewer on my server as follows:
SQL Server has encountered 1 occurrence(s) of cachestore flush for the 'SQL Plans' cachestore (part of plan cache) due to some database maintenance or reconfigure operations.
It's an Event ID of 2803, and before you say it Joe, I have searched Google and can find only obscure references and alot of Geek talk and you know I'm about as far away from being a geek as anyone can be.
Mark Gordon
Webmonkey
28 Aug 2008 9:13 AM
Mark,
This is a new one one me ... so I'll have to ask another stock question.
Which version of SQL Server are you using?
I'll do some research and see if I can come up with any ideas ...
mgordon
28 Aug 2008 9:15 AM
Thanks Joe,
I'm using SQL Server 2005 (Not Express, but the full version)
Mark
Mark Gordon
Webmonkey
03 Sep 2008 10:12 AM
have you had any luck finding this one? I have not come across this error before, thanks,
mgordon
03 Sep 2008 12:29 PM
No luck as of yet.  I'm thinking of kicking this up to Mitchel Sellers.
Mark Gordon
Webmonkey
03 Sep 2008 7:56 PM
I haven't found anything that would help you, but I'd love to hear the answer ...
Forums > Users Lounge > Everything Else > My Server's Event Viewer
