Subject: Javascript link in skin
eureka
24 Aug 2008 2:54 AM
Hi Lee
At the bottom of your skins you have a javascript code to call up the IE hacks and print css files; is there any reason why you do not have this javascript file stored in your skin folder and just a link to it instead?
Lynn
27 Aug 2008 3:05 AM
no there is no reason, thanks
Forums > Users Lounge > Everything Else > Javascript link in skin
