Subject: Is anyone knows anything about this application?
zaad
17 Aug 2008 9:49 AM
My Dotnetnuke is Slow speed when loading page the first time.
I heard that there are some applications increase the speed of loading ..
I found this application (KeepAliveForever) and I want Install it on the my site, but I'm not sure it.
Does anybody have any feedback about this application?
17 Aug 2008 12:06 PM
Yes, your site is "slow" because, after a period of inactivity, it's unloaded and must be reloaded.
If you control your server, you can change the timeout period in IIS. If not, you can use any of a number of keep-alive services. KeepAliveForever will do that for you.
zaad
17 Aug 2008 1:48 PM
Thank you my dear:
But use this application has no problems on hosting company or any other problems.
17 Aug 2008 8:17 PM
No, this runs on another server and just pings your site every few minutes.
I actually use a product called KeeperUp that I found at Snowcovered. If runs on my computer, and seems to work just fine.
zaad
18 Aug 2008 4:19 AM
Thank you very much my Friend..............
eureka
24 Aug 2008 3:01 AM
Hello zaad
You will find that Pageblaster found here (link below) will  speed up your site.
http://www.snapsis.com/
Also as an alternative http://www.montastic.com does a similar job to keep alive and it is free
Lynn
zaad
24 Aug 2008 9:02 AM
eureka
Thank you for this information.
Forums > Users Lounge > Everything Else > Is anyone knows anything about this application?
