Subject: Need help for Efficion Consulting Article module
smyagnik
06 Aug 2008 9:36 AM
hi
i need a help for Efficion Consulting Article module
i want to Display article on a page accept last entered article...
so can u tel me the sql query which i can enter in custom select for needed result
thanks
07 Aug 2008 7:52 AM
I don't have any experience with this module, but I would think that you should try to do this using the settings for the module. I'm not sure why you would want to do this with an SQL query. Can you explain?
smyagnik
08 Aug 2008 8:54 AM
hi craig
thanks for your reply
i check all the settings but there is no option like that
i want cuz i want to show the last article with thumbnail & other article just the text link
in the module there is a option of both type but u cant make it in the same module...so what i m planing put two module one with thumbnail & below that only text link module
regards
13 Aug 2008 8:29 AM
Have you contacted Efficon?
Forums > Users Lounge > Everything Else > Need help for Efficion Consulting Article module
