Subject: Module for contact manager
tfesta
04 Aug 2008 5:18 PM
I am looking for a contact manager module which I would consider a very watered down version of Act!  I have tried the Universal Defined Table but really am looking for a paid module that does certain things out of the box.  It will essentially by used by sales people to enter in their contact info (or import contacts), print Avery 5160 labels very simply (not exporting to a csv and them mail merge), categorize the contacts,  keep track of when the contact was made, etc. Does a module like this exist "out of the box"?
04 Aug 2008 9:35 PM
Googling for "DotNetNuke Contact Manager" brings up quite a few references.
There is also Active CRM from Active Modules. It is a stand alone ASP.NET application, and not a DotNetNuke application.
Also, Googling "DotNetNuke CRM" brings up more references.
I haven't had any experience with any of these, so I can't make any recommendations. But, do let us know what you find so that the next person asking will at least have a partial answer.
tfesta
05 Aug 2008 10:09 AM
Thanks for the reply. I've been looking pretty hard on Google, Snowcovered and multiple other search engines using every derivation of Dotnetnuke, DNN and any word I could think of that may reference a contact manager.  I've found Active Modules and that is overkill for what I am looking for in terms of implementation and costs.  I'm going to see if SigmaPro 7.0 from OnyakTech can be used but that seems like overkill (not the cost which seems very reasonable) or if UniversalList from CookDNN can work.  It seems there would be a market for an online "rolodex". Sales people pay a lot to vendors like Top Producer and other online vendors to host a rolodex type of program.
07 Aug 2008 7:56 AM
There is a business card template for the Repository module.  If it isn't sufficient, you might be able to modify the template to fit your requirements.
If that isn't enough, the UDT module might work for you.  It is quite customizable.  You can create views that can be edited by the user, too.   Take a look at User Defined Table (UDT) DotNetNuke Core Module for some ideas.
Forums > Users Lounge > Everything Else > Module for contact manager
