Subject: need help to show breadcrumb in different way
smyagnik
19 Jul 2008 7:58 AM
hi..
i m new to DNN & i m makeing intanet site in DNN  i want the information regarding the page parent Tab ID Title.. iwant to show
This is my sitemap
home
business & Finance
--- Administration
------- Policies
To show Policies page Title i put <%=PortalSettings.ActiveTab.Title%> script & it work for me
The same way i want show, above the page title script, page parent .. means in my case i.e. Administration... shw what is the script?
i tried <%=PortalSettings.ActiveTab.BreadCrumb.count-1%>
but is shows me the numaric figur but i want to show page name
thanks
Satish Yagnik
email:smyagnik@gmail.com
22 Jul 2008 6:20 AM
< %=PortalSettings.ActiveTab.BreadCrumbs(PortalSettings.ActiveTab.Level - 1).TabName % >
For tips on these, there is a forum post at snapsis
smyagnik
22 Jul 2008 6:44 AM
hi
Thanks for ur reply... it is working correctly...
Thank u very much
Forums > Users Lounge > Everything Else > need help to show breadcrumb in different way
