Subject: Can't edit settings
Liz
18 Jul 2008 2:17 AM
I have a very serious problem. In the module settings, anything that requires you to click to open up settings e.g. Page Settings doesn't work. What happens is that it opens up, but then the page is continuing to load and once finishes collapses it again. So you get to see it for a few moments before it dissapears.
Obviously this is quite a critical issue. It only though seems to affect certain computers. I was wondering if it was a McAffee problem, but surely lots of people are using McAfee in which case I would have expected there to have been other people experiencing this issue.
The fact that I can't seem to find anything about the problem elsewhere is really strange - posting on the DNN forums has only found one other person who has the same problem who also can't find a solution.
So if anyone has come across this and can help resolve this, please let me know and I will be very grateful. My only way of updating my site atm is using a very old laptop which is on its last legs and annoying to use.
Liz
Liz Christopher
www.localparent.co.uk
www.busykiddies.co.uk
18 Jul 2008 5:49 AM
If you've enable AJAX in the Host Settings, you might want to disable it and see if that is the problem.
You didn't say which browser you were using. Does this happen in both IE and Firefox, or only one?
Liz
19 Jul 2008 1:50 AM
You have hit the nail on the head. I was using IE 7, just tried it in FF and it works fine. Must be an IE 7 problem, The old computer is running IE 6 hence why it works. Still surpirsed that more people haven't had the problem, I can't believe everyone is using FF. I don't like using FF as it is very chunky, ie is prettier to use (guess that is a bit girly but hey!!!). I only use FF when I need any of the developer addons, e,g when wrestling with stylesheets.
Liz Christopher
19 Jul 2008 7:32 AM
I haven't seen that problem with IE, but I'm always finding differences. Using an XHTML skin is usually better than not.
The new Firefox is less "chunky" that earlier versions ... so they tell me.
robax
20 Jul 2008 5:37 AM
This appears to be happening because of McAfee products. I'm testing it now.
Rob
Forums > Users Lounge > Everything Else > Can't edit settings
Have a look at the tabs table
page publish date by dnnwebuser
HiI would like to know the table to get page information(page name,publish date and time).Could you ...
RE: Keep Testing Skins by leesykes
For the downloads from DNN Creative you should not have to rename.When you upload the skin zip it sh...
RE: Old style skinning by leesykes
If you are using the logo skin object you should not get any repeat problems. I can't really tell fr...
Have you tried to re-apply the permissions for Network Service across the entire installation files?...
I have not added line breaks in before like that, most of the time I would setup a menu to just wrap...
on the part 6 page, amongst the video links is a link named:Vortex Music Skin Stage OneThese are the...
RE: Query regarding Site Log by leesykes
Once you start enabling logs, also make sure you schedule to delete the old logs:Site logs, Event lo...
RE: How to speed DNN by vdelisi
It could be related to the use uf resx file to localize the portal. I'm thinking about that becau...
Keep Testing Skins by ollep
Thanks for your reply Yesterday Lee. I will do a new upload and see if I can get the template worki...
RE: 3Essentials Hosting by nlssolutions
I wanted to post an update about 3Essentials. I had a few struggles with speed and some modules tim...
RE: Old style skinning by adrian_scott_day
Lee, The Logo skin object doesn't seem to have a property for setting a CSS Class. I'm using the sk...
RE: redirecting registered user to a specific page by jncraig
Go to the User Settings page under Admin. On that page, pull down the menu and click on User Settin...
RE: Building a website with DNN by jncraig
At the bottom of the page you will see the links for the various parts of the tutorial.  If you clic...
RE: How do i change the global font of the site by balousta
Thank you for your advice, I have seen the  tutorials long time ago, but I'm not good in css in gene...
Lee,Thanks for your suggestion about checking event log.  Here's what I did...First, in site Admin>>...
redirecting registered user to a specific page by saintX
Hello,Is it possible to redirect a user after registration to a specific page? If yes, please tell m...
Solpartmenu and line breacks by saintX
Hello,I have to make linebreacks on Solpartmenu, okay I do it using . Bur the secound line appears o...
Hi Joe,   Thanks for your reply. I have looked at those links and I can't seem to find the files f...
RE: Query regarding Site Log by puuri
Joe is exactly right with his suggested fix for your problem. I am very new with DotNetNuke and ran...
