Subject: Ski Links
rogerg1967
08 Jul 2008 4:18 PM
I am trying to change the style of a link I am putting in the bottom bar of my page. This bar holds the terms, login, privacy etc. I am adding a link to my web site from this same bar . The link to my web site is taking its style from the a.link class where the others are taking the skin object link class. Is there any way to assign the same style to the link to my web site?
Regards
Roger
08 Jul 2008 6:56 PM
Sure, all that you need to do is change its cssclass in the skin, and provide a style in skin.css.
rogerg1967
09 Jul 2008 2:12 AM
I already have a style for my a.links which has been setup for the main content area. The problem is that the bottom bar is a dark colour and the text of the link is black therefore you cant see the text when its on the bottom bar. If there is a way to assign a new set of style to act as a link then I am not sure how I would do this. If you can give me an example of how the code would look I shouold be able to work it out.
Regards
09 Jul 2008 9:04 AM
If you give that link a special class, then you can style it separately from all of the other links. You assign a class to the link by placing class="MyClass" in the link tag.
