Subject: Custom HTML Skin - link module center overridden with left align
aggiedan97
01 Jul 2008 10:52 PM
DNN 4.7.01
Browser: Firefox 2.x
Attached Custom HTML skin file, CSS file,
Note - container skin = dnn blue (to simplify)
Skins don't get more simple than this.  I have attempted to clean up many of the HTML tags and move them to the CSS file.  In doing so, I seemed to have made the 'Links' module content not able to "center" as it would before I started to make changes.
The panes in question are the RightPane and LeftPane.  Both contain different Links modules with a single entry each.
The HTML for this section includes:
< table cellpadding="0" cellspacing="0" width="100%" border="0" >
    < tr
        < td class="contentpane" id="ContentPane" runat="server" align="center" colspan="2" >< /td
< /tr
    < tr
        < td align="center" class="leftpane" id="LeftPane" runat="server" >< /td
        < td align="center" class="rightpane" id="RightPane" runat="server" >< /td
    < /tr
< /table
The CSS for these classes include:
.leftpane
width: 50%;
padding-left: 6px;
padding-right: 4px;
padding-top: 6px;
vertical-align: top;
text-align: center
.rightpane
width: 50%;
padding-left: 6px;
padding-right: 4px;
padding-top: 6px;
text-align: center
I have commented out most of the other 'text-align' in the CSS to no avail.   (Please see the attached CSS for more details.)
I used the dnn-blue container: image headder with color background, to simplify things.
Attachment: 171543231554.zip
02 Jul 2008 4:07 AM
This was an interesting one!
The problem comes with how you add a module to the page.
When you add a module, there is the align option. - Select 'None Specified'
This will allow the correct styling to come from the skin.css
I experimented with using align center when adding a module, but this did not work. - View the page source to see how DNN adds additional classes into the module area
and the align classes are specified in the default.css
/* used to set the different module align options - from module settings */
.DNNAlignleft
    text-align: left;
.DNNAlignright
    text-align: right;
.DNNAligncenter
    text-align: center;
I discovered if I removed these classes, DNN modules aligned correctly, so selecting 'none specified' avoids using these classes.
aggiedan97
02 Jul 2008 5:25 AM
As suggested, I changed the module align settings to 'Not Specified' under the module > Settings > Page Settings > Alignment.
In Internet Explorer - no worries; Firefox 2.x - worries.
Interestingly, when in Edit mode the links text aligns center as desired, but in view mode it aligns left. When I view source < a class="Normal"... > is assigned to the actual link anchor for the entry.  See below:
< !-- End_Module_392 -- >
< /div >< /span >
< /td >
                            < /tr >
                            < tr >
                                < td id="dnn_LeftPane" class="leftpane" align="center" >< a name="377" >< /a >< span id="dnn_ctr377_ContentPane" >< !-- Start_Module_377 -- >< div id="dnn_ctr377_ModuleContent" >
 < div id="dnn_ctr377_Links_pnlList" >
    < table id="dnn_ctr377_Links_lstLinks" cellspacing="0" cellpadding="0" summary="Links Design Table" border="0" style="border-collapse:collapse;" >
   < tr >
    < td valign="top" >
            < table border="0" cellpadding="4" cellspacing="0" >
                < tr >
                    < td nowrap >
                        < a class="Normal" href="/DNN4701_02/LinkClick.aspx?link=65&tabid=58&mid=377" target="_self" >Enter Site< /a >
                    < /td >
                < /tr >
                < tr >
                    < td >
                    < /td >
                < /tr >
            < /table >
        < /td >
   < /tr >
  < /table >
 < /div >
< !-- End_Module_377 -- >
< /div >< /span >
< /td >
                                < td id="dnn_RightPane" class="rightpane" align="center" >< a name="378" >< /a >< span id="dnn_ctr378_ContentPane" >< !-- Start_Module_378 -- >< div id="dnn_ctr378_ModuleContent" >
 < div id="dnn_ctr378_Links_pnlList" >
    < table id="dnn_ctr378_Links_lstLinks" cellspacing="0" cellpadding="0" summary="Links Design Table" border="0" style="border-collapse:collapse;" >
   < tr >
    < td valign="top" >
                < tr >
                    < td nowrap >
                        < a class="Normal" href="/DNN4701_02/LinkClick.aspx?link=61&tabid=58&mid=378" target="_self" >Enter Blog< /a >
                    < /td >
                < /tr >
                < tr >
                    < td >
                    < /td >
                < /tr >
            < /table >
        < /td >
   < /tr >
  < /table >
 < /div >
< !-- End_Module_378 -- >
02 Jul 2008 5:46 AM
I tested this in FF. - Does the links module display correctly when logged out?
aggiedan97
02 Jul 2008 6:56 AM
No it displays incorrectly when logged out.
04 Jul 2008 9:20 AM
Not sure what is happening here, I tested again in FF2 in view mode and the links are centered.
I have attached a zip with the source code of my install along with the skin files so that you can double check the code for any differences,
Attachment: 174205842871.zip
Forums > Users Lounge > Everything Else > Custom HTML Skin - link module center overridden with left align
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
