Subject: active directory
rizwan7705
12 Jun 2008 6:28 AM
is there anyway if i can use active directory security role structure in dnn.i mean if i configer dnn with active directory and create security role in active directory and use them in dnn. is it possiable?
Nuke Master I
Nuke Master I
12 Jun 2008 7:15 PM
You can use Active Directory with DotNetNuke. There is an Active Directory Authentication Provider that is part of DotNetNuke.
Forums > Users Lounge > Everything Else > active directory
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
