Subject: "Terms of Use - Link wordin"
Carmos
02 Jun 2008 10:35 PM
Is there a way to change the Wording of the Link for "Terms of Use" to say "Disclaimer"?
03 Jun 2008 6:05 AM
Go to:
Admin menu
Languages
Language Editor
Local Resources
Admin
Portal
App_Local_Resources
Terms.ascx
Here you can edit the text
Carmos
04 Jun 2008 2:25 AM
Lee,
Thanks for that. That allowed me to change the text, but still did not update my pages.
Further investigation revealed that in my skin, I had this line
Register TagPrefix="dnn" TagName="TERMS" Src="~/Admin/Skins/Terms.ascx"
So when I edited that ascx with Notepad, it resolved the Link Wording.
05 Jun 2008 3:38 AM
I spotted a mistake, that was the incorrect language text to edit - it should be in the skin folder, further info below:
Yes, just to clarify for anyone else reading. - You can hardcode the text in your skin with the following method:
In the skin.ascx at the top you will have:
< % @ Register TagPrefix="dnn" TagName="TERMS" src="~/Admin/Skins/Terms.ascx" % >
and then in the skin content you have the details for the Terms token:
< dnn:TERMS runat="server" id="dnnTERMS" / >
To change the text of the Terms token you can also add this:
< dnn:terms runat="server" text="MyTerms" id="dnnTERMS" / >
This hardcodes the text in your skin and overrides any localization settings, so for instance if you change the language the Text will still display "MyTerms" if you want the localization settings to work, use:
< dnn:terms runat="server" id="dnnTERMS" >
and then change the text using this method:
Go to:
Admin menu
Languages
Language Editor
Local Resources
Admin
SKINS ****** (this is the correct location now!)
App_Local_Resources
Terms.ascx
Lee
Forums > Users Lounge > Everything Else > "Terms of Use - Link wordin"
