Subject: control panel keeping rolling up
rizwan7705
19 May 2008 9:25 PM
i have installed dnn 4.8.2 on w/host.
the problem is i see rolled up control panel and when i click to pull down the control panel
comes down but as page loads up completly. the control panel rolls up automaticly. i m having same problem in other features too like if i click to other option i mean plus sign they come down and go up again i m worried  please
help me i cant add pages and madules or nothing plz help me in it lee thanks
thanks
19 May 2008 11:09 PM
I haven't heard of that before. I'd check to make sure that AJAX and Java are installed correctly. Does this happen on multiple computers?
rizwan7705
20 May 2008 5:55 PM
how would i check ajax and java installed correctly?and yes it is happening on every computer i tried 3 so for plz help me in this
20 May 2008 8:41 PM
Hmmm ... this is an odd one. Can you perhaps make a second DotNetNuke installation and see if it happens there as well.
rizwan7705
21 May 2008 4:12 AM
thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfox it is working fine.i guess microsoft shud learn how to develop explorer.
21 May 2008 7:24 AM
Well ... I haven't seen this problem in IE, so your job might not be over ...
Forums > Users Lounge > Everything Else > control panel keeping rolling up
