Subject: Screen Capture Software for DNN Videos
omorgan
13 May 2008 8:58 AM
Howdy,
I was wondering what screen capture software you are using to make the videos. I'd like to create some simple tutorial videos for my clients and been having some issues. I've been using camstudio, it works well but I can't convert them to wmv without severe quality degridation. So I thought I would ask.
Owen - http://www.fdwsnetworks.com
19 May 2008 7:02 AM
camtasia and captivate are programmes we use
omorgan
19 May 2008 2:28 PM
Brilliant thanks Lee, I think I sorted out my original problem also.
Forums > Users Lounge > Everything Else > Screen Capture Software for DNN Videos
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
