Subject: currency settings
mparrett
08 May 2008 10:06 AM
When I installed DNN (shared host) I did an automatic installation
All my currency settings are US
I am trying to get all to Uk, so in particular, I can have £ in my products not $
Have changed Web congig to GB
GB language enabled on Admin
Payment settings all say GB
Help would be appreciated!
Matt
10 May 2008 3:10 AM
So you have gone to the admin menu  / site settings / advanced settings / payment settings and selected currency "Pounds Sterling"?
I suspect it also depends on what store module you are using. Quite often they have their own configuration options for the default currency that the store should use.  I would have a look in your store modules settings and see if there is an option in there for currency.
mparrett
10 May 2008 5:22 AM
ah yes, i was on the older moduler
have upgraded and it works fine!
thanks
Forums > Users Lounge > Everything Else > currency settings
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
