Subject: Store - Connection Timeout error
buppertb
27 Apr 2008 1:23 PM
When updating store items I frequently get an connection pool error and the site is not accessible, does anyone know how to resolve? TKS for the help,
BB3
30 Apr 2008 3:53 AM
I have not come across that problem,  are you doing anything in particular when the error occurs?
Forums > Users Lounge > Everything Else > Store - Connection Timeout error
