Subject: How to modify a Page Template
peter.rose@tekenable.com
19 Mar 2008 1:42 AM
Hello Everyone,
I have developed a website portal and used two Page templates in it. every thing is working fine, but i m facing a problem when i want to modify my page template and want to apply those changes on my portal web pages it just dont work. but when i create a new page that template work perfectly fine.
please if anyone help me on this regard i will really appriciate it.
19 Mar 2008 8:49 AM
The page template only acts when you create a new page.
Forums > DotNetNuke® > Quick Tips > How to modify a Page Template
Glad you sorted it, thanks,
