leesykes DNN Creative Staff
 Nuke Master III Posts:3325
kigkapu
 Nuke Newbie Posts:2
| 21 Sep 2006 1:05 PM |
| Anyone please help; I accidentally set login page under home page. Then every time when I click on login then it will link to home page. What should I do to fix this problem. pleaseeee help |
kigkapu
 Nuke Newbie Posts:2
| 21 Sep 2006 10:59 PM |
Yes, I already follow the above method but it couldn't work out. As I set login link to home page so everytime I click on login; it will come up on my home. Do I need to re-install it again to fix it? God; this is the last choice for me.
Thanks |
| 22 Sep 2006 2:42 AM |
Which version of DNN are you using? If it is below DNN 4.3 / 3.3 uploading the login file that is available for download from the blog link works every time.
If you are in DNN 4.3 / 3.3 - Can you access your SQL database? In the blog link there is a SQL statement that you can use to fix the problem. - I haven't tried this out but it should work.
If you can't access your SQL database, perhaps you could send a help ticket to your hosting provider to see if they will run the SQL statement for you?
This is the only option that you have left as far as i know, otherwise it will mean a re-install. - Unless your hosting provider keeps regular backups of your site - you could ask them to install the backup version.
Hope you manage to get it sorted without re-installing, let us know how you get on, thanks, |
eatanasov
 Nuke Newbie Posts:1
| 02 Nov 2006 2:05 PM |
If you have FTP access to your DNN installation there is a very simple thing that you can do. Go into
Portals/_default/Skins
and either rename or delete the directory that contains the skin with the forgotten. Then refresh your browser. The default DNN skin kicks in to take the place of the missing skin that is supposed to be there and voila you have your Login link again. |
Ventana
 Nuke Active Member Posts:22
| 06 Nov 2006 3:03 PM |
| I made a boo-boo. I think I accidentally removed All Users from View permission on the Login page setting. I can't even view the page. How can I solve this problem? |
Ventana
| 06 Nov 2006 3:09 PM |
I can't login. I can't even see the login page. www.mysite.com/default.aspx?ctl=login gives a page error |
Ventana
| 06 Nov 2006 3:29 PM |
| I'm on localhost. |
Ventana
| 07 Nov 2006 1:13 PM |
| After running the SQL statement, I got this error message on my pages An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) . |
Ventana
| 15 Nov 2006 9:40 AM |
I entered: Update Portals Set LoginTabId=null Where PortalId=0 There seemed to be a conflict between SQL 2005 and SQL Express which I had both installed in my PC. Anyway, I have resorted to reformatting my PC and start over again. |
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 2:15 AM |
Hi, I have a problem login in. I have installed DotNetNuke on my localhost, and the installation was successful, but when I tried to login like Administrator, with the password I set in the installation process it didn't get me to the Edit-Page but I get me to the Home-page. I can't edit my WebPage. Please help.... |
jncraig DNN Creative Staff
 Nuke Master II Posts:2318
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 8:51 AM |
| no, I don't. |
| 11 Jul 2008 8:58 AM |
| You might want to try to use a tool like Fiddler (google to find it) to get a trace of all of the http calls and redirects. Perhaps something there will tell you what's happening. |
| 11 Jul 2008 9:00 AM |
I've got to believe that there is something going on with IIS that is causing this. Are there any host headers or other things associated with your website? Is there any chance that you can try doing an install on another computer? |
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 9:01 AM |
Ok, I'll try with it.. thanks. |
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 9:13 AM |
I tried to install it on other computer, but there I get into new problem trought the installation process. I get an error there that tell my to allow remote connections to the Server, so I did it but I still get the same error. so I don't know what to do there eider. And I don't have no other things associated with my website on the both computers. |
| 11 Jul 2008 5:12 PM |
| If you can't connect to the server, problems that you might be having could be related to that issue. |
Verce
 Nuke Newbie Posts:8
| 16 Jul 2008 9:57 AM |
Hey... I try on Mozila and it worked I didn't change anything. Thanks anyway |
