Subject: Fix FCKEditor showing background image in editor
webbo
17 May 2006 1:08 PM
I setup FCKEditor the same as detailed in the videos and experienced a similar problem in that my repeating bacground image was being repeated inside of the editor pane even though on my website the content area was specifically set to have a white background, positioned as a div layer on top of my background image.  You know the type, repeating background gif with centered content in white content pane.
I managed to fix this by altering how I define my background image in my CSS.  Instead of having:
body
    background-image: url(bg.gif);
    font-family: Tahoma, Arial, Helvetica;
    /* For IE5.5 and below */
    font-size: x-small;
    voice-family: "\"}\"";
    voice-family: inherit;
    /* For IE6 and all other browsers */
    font-size: small;
I created a new .body id style and moved the background-image definition into that:
body
    font-size: x-small;
    font-size: small;
/* added seperate id spec for body to avoid background image in fckeditor */
.body
That way fckeditor doesn't pickup your background image when editing text.
Hope this helps some folks.
/Webbo
19 May 2006 6:05 AM
Thanks for the useful tip, will give that a try!
Forums > DotNetNuke® > Quick Tips > Fix FCKEditor showing background image in editor
