Subject: Adding Module
john20
24 Oct 2007 6:22 AM
Hi All,
I have created asp.net page now i want to add that page or whole project in Dotnetnuke as a module how can i do that, what are the steps can u tell me.
Thanks in advance.
-john
27 Oct 2007 9:08 PM
John,
If you are interested in converting existing ASP.NET pages into DotNetNuke modules, then you need to start with modules.
If the pages have mostly text and images, it might be possible to cut and paste into Text/HTML modules. I'd have to look at some of the pages to really make a good guess.
Chris@ICSIT
14 Jan 2008 10:54 PM
Writing a Module is very similar to writing a ASP.Net Page
Google for a few guides to writing Dnn Modules
Chris
www.icsit.com.au
www.icsit.com.au
15 Jan 2008 1:54 AM
There are resources listed here for DotNetNuke Module Development
Forums > DotNetNuke® > Quick Tips > Adding Module
