Subject: Find and Replace Procedure for Html Module
24 May 2007 2:45 AM
This is a tip from bi4ce. It allows you to correct URL errors in the text / HTML module. - For instance when you are moving a localhost installation to a live site more often than not the URLs are not correct, so using this procedure from bi4ce allows you to search for incorrect URLs and replace them with the correct URLs.
It also works for any text you wish to search and replace within the text HTML module:
http://www.bi4ce.com/tabid/106/forumid/2/postid/86/view/topic/Default.aspx
Forums > DotNetNuke® > Quick Tips > Find and Replace Procedure for Html Module
