NavigationProvider
Description
Paths
PathImage
Directory to find the icons
PathSystemImage
images necessary for the control (i.e. spacer.gif)
PathSystemScript
Directory to find
associated script files for the control
Rendering
ForceDownLevel
Flag to force the downlevel
menu to display (values: true, false)
ForceCrawlerDisplay
Displays the full menu as
an indented list of normal hyperlinks (like a sitemap) {true|false}
ControlOrientation
Determines how the menu is
displayed, horizontal or vertical (values: vertical, horizontal)
ControlAlignment
Alignment of the menu within
the menu bar. {Left|Center|Right|Justify}
Mouse Properties
MouseOutHideDelay
Number of milliseconds to
wait until menu is hidden on mouse out. (0 = disable)
MouseOverDisplay
Adjusts effect when mouse
moves over menu bar item (Values: Outset, Highlight, None)
MouseOverAction
Makes menu expand on mouse
over (unlike any menu found within the Windows environment)(Values: true,
false)
Indicate Children
IndicateChildren
use arrows to indicate
child submenus
IndicateChildImageSub
Arrow image to use for sub
IndicateChildImage
Arrow image to use for root
IndicateChildImageExpandedSub
Image to use on sub node
when children expanded
IndicateChildImageExpandedRoot
Image to use on root node
Custom HTML
NodeLeftHTMLRoot
HTML text added to the
beginning of the Root menu items
NodeRightHTMLRoot
HTML text added to the end
NodeLeftHTMLSub
beginning of the sub menu items
NodeRightHTMLSub
NodeLeftHTMLBreadCrumbSub
HTML to display to the left
of the node that resides in a submenu and is a breadcrumb
NodeLeftHTMLBreadCrumbRoot
of the node that resides in the root and is a breadcrumb
NodeRightHTMLBreadCrumbSub
right of the node that resides in a submenu and is a breadcrumb
NodeRightHTMLBreadCrumbRoot
right of the node that resides in the root and is a breadcrumb
SeparatorHTML
The separator between Root
level menu items. This can include custom skin images, text, and HTML (ie.
<!--[CDATA[ ]]--> )
SeparatorLeftHTML
The separator used just
before a root level menu item. A use for this might be a left edge of a tab
image for example
SeparatorRightHTML
after a root level menu item. A use for this might be a right edge of a tab
image for example
SeparatorLeftHTMLActive
before an active root level menu item
SeparatorRightHTMLActive
SeparatorLeftHTMLBreadCrumb
before a root level menu item found in the breadcrumb array list
SeparatorRightHTMLBreadCrumb
CSS
CSSControl
Menu Bar CSS Class
CSSContainerRoot
Menu Container CSS Class
CSSContainerSub
SubMenu CSS Class
CSSBreak
Menu Break CSS Class
CSSIndicateChildSub
Menu Arrow CSS Class
CSSIndicateChildRoot
Menu Root Arrow CSS Class
CSSNode
Menu Item CSS Class - ALL
Nodes
CSSNodeRoot
CSS Class used for root
menu items - Overrides CSSNode
CSSBreadCrumbSub
CSS Class used for sub menu
items when they are found in the breadcrumb array list - Overrides CSSNode
CSSBreadCrumbRoot
menu items when they are found in the breadcrumb array list - Overrides
CSSNode
CSSNodeSelectedRoot
menu items when they are the active tab - Overrides CSSNode,
CSSBreadCrumbRoot
CSSNodeSelectedSub
items when they are the active tab - Overrides CSSNode, CSSBreadCrumbRoot
CSSNodeHover
Menu Item CSS Class for
mouse-over - ALL Nodes
CSSNodeHoverSub
items when they moused-over - Overrides CSSNodeHover
CSSNodeHoverRoot
menu items when they moused-over - Overrides CSSNodeHover
CSSSeparator
CSS class used for the root
level menu item separator
CSSLeftSeparator
CSS class used for
leftseparator
CSSRightSeparator
CSS class used for
leftseparator
CSSLeftSeparatorSelection
CSS class used for
leftseparatoractive
CSSRightSeparatorSelection
CSS class used for
rightseparatoractive
CSSLeftSeparatorBreadCrumb
CSS class used for
leftseparatorbreadcrumb
CSSRightSeparatorBreadCrumb
CSS class used for
rightseparatorbreadcrumb
CSSIcon
Menu Icon CSS Class
Styles
StyleBackColor
Background color
StyleForeColor
Fore color of menu item
when selected
StyleHighlightColor
Color of top and left
border to give a highlight effect
StyleIconBackColor
Background color in area
where icon is displayed
StyleSelectionBorderColor
Color of border surrounding
selected menu item
StyleSelectionColor
Background color of menu
item when selected
StyleSelectionForeColor
when selected
StyleControlHeight
Menu bar height in pixels
StyleBorderWidth
Menu border width in pixels
StyleNodeHeight
Menu item height in pixels
StyleIconWidth
Width of icon column in
pixels
StyleFontNames
Fonts to use
StyleFontSize
Font Size Style
StyleFontBold
Font Bold Style
Animation
EffectsShadowColor
Color of the shadow
EffectsTransition
Determines which transition
to display
EffectsDuration
Number of seconds the
transition will take
EffectsShadowDirection
Determines which direction
the shadow will fall
EffectsShadowStrength
Determines how opaque the
shadow is
EffectsStyle
IE only property for
SubMenu styles and transitions
