Subject: How to change the "Terms of Use" and "Privacy Statement"
08 Sep 2005 3:42 AM
 To edit the Privacy and Terms:
1) Go to: Host / Languages
2) Click on Language Editor
3) You will be presented with a list of templates you can edit
4) Scroll down, select
5) MESSAGE_PORTAL_PRIVACY.Text
6) MESSAGE_PORTAL_TERMS.Text
7) If you click on the arrow to the right hand side of the text box, it will open up the Text Editor so that you can make any alterations necessary.
Forums > DotNetNuke® > Quick Tips > How to change the "Terms of Use" and "Privacy Statement"
