Subject: Looking for Older DNN Versions?
mgordon
26 Aug 2008 11:57 AM
SourceForge has these files located here:
http://sourceforge.net/project/showfiles.php?group_id=77052&package_id=77939
Go there and download whichever version you need to be able to upgrade to current versions.
Peace!
Mark
Mark Gordon
Webmonkey
27 Aug 2008 4:07 AM
that is a handy page!
Forums > DotNetNuke® > Quick Tips > Looking for Older DNN Versions?
