Subject: Free website monitor
eureka
24 Jul 2008 6:03 PM
Hello
This is a useful Free service to monitor your website, which informs you when it is down, plus it keeps your website alive.
http://www.montastic.com
Lynn
inetwiz
19 Aug 2008 5:33 PM
Another free site monitor website is http://www.contentsitemonitor.com
This site allows to you to perform "content check" to make sure that the response contains certain strings or phrases that you specify. It will send you an alert email if the strings or phrases do not get returned.  Pretty neat site!
Forums > DotNetNuke® > Quick Tips > Free website monitor
