Subject: Skin from Dnncovered
masim
01 Apr 2008 2:52 AM
Kindly find some nice skins developed by Dnncovered.These skins are ready to sell in snowcovered site only.
Handyman dnncovered 4 color skin
http://www.snowcovered.com/snowcovered2/Default.aspx?tabid=242&PackageID=10172
AE Big both in DNN and HTML versions
This skin pack is avaliable in both DNN and HTML versions.
http://www.snowcovered.com/snowcovered2/Default.aspx?tabid=242&PackageID=10121
Real Estate City DNN and HTML versions Dnncovered
http://www.snowcovered.com/snowcovered2/Default.aspx?tabid=242&PackageID=10108
Biz3
This is nice color combination of skin with different containers.
http://www.snowcovered.com/snowcovered2/Default.aspx?tabid=242&PackageID=9926
There are many skins posted by Dnncovered and the out come ratio is 2 skins per day.
Kindly share your views.
Regards
Asim
Forums > Users Lounge > Announcements > Skin from Dnncovered
Member log in by HUGHD37IUOE
Video Problem by icdlbake
