Subject: DotNetNuke 3.1.1 Released
22 Aug 2005 6:19 PM
A new version of DotNetNuke has just been released today!
The latest version is a Stabilization release focusing exclusively on defect corrections, performance, quality assurance, and security enhancements for the 3.1 platform. With over 70 issue resolutions recorded in our Issue Tracker ( Gemini ) and over 800 transactions logged in our Source Code Repository ( Vault ), it should be obvious that the Core Team has not been resting this summer.
To download the latest version, visit this page:
http://www.dotnetnuke.com/Default.aspx?tabid=125
I have upgraded this site to V3.1.1 and all went smoothly. I tested it first on several localhost installs and another live website to make sure there were no conflicts with any modules.
Make sure you test thoroughly & backup first before doing any upgrades - just incase!
Forums > Users Lounge > Announcements > DotNetNuke 3.1.1 Released
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
