Subject: DotNetNuke Competition for Bi4ce Nukedk module and DNN Creative Subscription
19 May 2006 5:38 AM
Nukedk module from Bi4ce ($69) and a free Subscription to DNN Creative ($39) for this months Flash Game Competition Giveaway.
Another game competition to take you away from work ;-) …
This month Bi4ce have kindly donated their Nukedk module as a prize to DNN Creative.
Achieve the top score playing either Invaders (for Nukedk) or PacMan (for DNN Creative subscription) and enter your DNN Creative username into the scoreboard. The top score at the end of the month wins.
The closing date for the competition is 17:00 GMT on the 19th June 2006
If you are already a subscriber to DNN Creative you will receive a year extension on your current subscription.
No cash alternative is provided
Please make sure you are registered on DNN Creative with a valid email as we will use your username and email address to contact you if you win the competition.
Hope you enjoy the games!
Forums > Users Lounge > Announcements > DotNetNuke Competition for Bi4ce Nukedk module and DNN Creative Subscription
