Subject: digFlash 1.0.0
digmike
13 Nov 2007 8:47 AM
digFlash is a FREE module that allows you to easily add a Flash .swf files to your DotNetNuke page.  digFlash is a wrapper around the popular swfobject framework.
  • Specify width and height of your flash module
  • Specify required Flash version (7,8,9)
  • Specify variables and values to pass to your swf object
  • Auto install the latest flash player if version requirement not met.
  • Eliminates Internet Explorer Active Content Update message.
  • Supports multiple digFlash modules on a single page
  • Support DotNetNuke 4.x, IPortable, and Localization
  • It's FREE!
For further details, and download please visit digNuke.com.
Mike
dignuke.com
Forums > Users Lounge > Announcements > digFlash 1.0.0
RE: Pop up window by jncraig
Pop up window by yerann
