Subject: Las Vegas!
08 Nov 2007 6:19 PM
I'd like to apologize to everyone who hasn't had their question answered this week.  I've been in Las Vegas attending the Open Force 07 Conference -- a conference devoted to DotNetNuke.  I've had a chance to hear some great presentations, meet many of the DotNetNuke teams members, hear about plans for the future development of DotNetNuke, and ... best of all ... I've had the chance to meet Lee Sykes!
So ... as the conference is now winding down, it's time for me to dig into your questions!
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
