Subject: DotNetNuke V3.2 and 4.0 released
08 Nov 2005 6:53 AM
DotNetNuke V3.2 and 4.0 have just been released today!
These releases bridge the compatibility gap between ASP.NET 1.1 and ASP.NET 2.0 and offer a number of powerful new application features.
You can read further details here:
http://www.dotnetnuke.com/Default.aspx?tabid=886
and download the latest releases from here:
http://www.dotnetnuke.com/tabid/125/default.aspx
- I've done some preliminary tests upgrading a localhost install of V3.1 to 3.2 and it installed without any problems.
Forums > Users Lounge > Announcements > DotNetNuke V3.2 and 4.0 released
