Subject: Blog Module core DotNetNuke project released
02 Nov 2005 6:56 PM
Congratulations to the Blog module core project team, the new blog module is now available for download:
http://www.dotnetnuke.com/Community/Blogs/tabid/825/EntryID/218/Default.aspx
Feature Summary:
  • Blog for Multiple Users
  • Categories (sub blogs)
  • Comments for blog entries
  • Email notification for new comments
  • Blog archive
  • Extended RSS Handling implemented (RSS 2.0 XML)
  • ISearchable Interface implemented (DNN Search)
  • IPortable Interface implemented (Import/Export)
  • IUpgradeable Interface implemented (Upgrade NewBlog)
  • Cross- grade procedure for NewBlog implemented
  • Import function for the discontinued Forum/Blog module implemented
  • Track back client and server feature implemented
Forums > Users Lounge > Announcements > Blog Module core DotNetNuke project released
RE: How to Create Module : by jncraig
I'd recommend the book on DotNetNuke module development by Mitchel Sellers, and also adefwebserver.c...
RE: Change Login Page by jncraig
If you want to add modules to the login page, first create on and add the login module. Then add ot...
RE: Background colour by jncraig
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by arm
Posted By mnaoj on 04 Dec 2008 11:46 AMError 1 It is an error to use a section registered as allowDe...
How to Create Module : by hassangas2003
this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old pro...
Background colour by petecarrick
Hi,Sorry if this is a real dumb question, I've been experimenting with the Vortex skin and I have ch...
RE: Horizontal menu vertical borders by petecarrick
That worked perfectly, thanks very much Lee.Pete
Change Login Page by edeakin
Hey guys it’s me again. Great work on session 46 keep up the great work! I want to be able to add m...
RE: Module Wrapper & Tab Aggregator?? by gbrown
Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggreg...
Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DN...
RE: SWF Tutorial Conversion by raymueller
Thanks and I will continue to research. Each of the applications pick up the introduction (~ 20-25 s...
RE: Please do review by leesykes
There are a couple of things that you could look at:Initial page load time of the sites was slow, t...
RE: Module Development - Settings Page by leesykes
thanks for letting us know the solution and if there's anything else we can help out with please let...
RE: SWF Tutorial Conversion by leesykes
not sure, its not something I have tried, the swf should convert, perhaps its worth googling around ...
RE: not been able to download videos by leesykes
RE: Styling the main menu by leesykes
When you add code to your skin.css file, make sure you press CTRL+F5 to reload the page and reload t...
RE: Horizontal menu vertical borders by leesykes
To find the id of the menu item, use the web developers toolbar for Firefox, go to information menu...
RE: Module Development - Settings Page by HMDevelopment
Hello Lee. No thanks -- I have still earned value from this site. I did quite a few 'video' tutor...
RE: Can I modify the Default Events module only for a Portal? by jncraig
If you create a skin for your site, it will apply only to your site.  Also, portal.css applies only ...
RE: How to prevent auser from multiple login. by jncraig
