Subject: Free DNN TransMenu implementation ready to use
bhutten
11 Jul 2007 10:34 AM
Hi all,
I made a rough implementation of the cool TransMenu 2.0 for DNN (4.5.3) and would like to share this with you. No guarantee for working, but have a try, it's free.
You can see my implementation here, just hover over the different menu items: http://www.gbsdeplantage.nl, it's very cool!
You can download it here: http://www.bsoft.nl/TransMenu.zip. Read the installation.txt its quite simple to use.
Regards,
Berthold
11 Jul 2007 4:30 PM
Interesting stuff - I've moved this to the announcements forum.
Lee
video1
26 Jul 2007 2:38 PM
Berthold,
Cool indeed! Hartelijk dank.
I did have to make a small adjustment before I got it to work. In transmenu.ascx removed the trailing slashes: "/admin/skins/transmenu" to "admin/skins/transmenu".
Final remaining problem is getting the submenus starting to dropdown a little lower below the "root-items". Judging from the http://www.gbsdeplantage.nl you might have had the same problem, right?
Thanks again for sharing.
bhutten
26 Jul 2007 3:36 PM
It's great to hear it works on your site. I do not have issues with that slash.
Hmmm you mention the spacing between the main items and the dropdowns... I didn't noticed it before. It's something of transmenu I guess. Have a look in the tansmenu.js file, in the top of that file there are some settings you may change, maybe this helps.
Regards,
Berthold
trentb
07 Aug 2007 7:34 PM
I am unable to download the zip file from your link. Do you have a link that works, it looks cool and I would like to try it out. thanks
Breuk
21 Aug 2007 6:57 AM
The download link doesn't work. Is there an other link ?
'cause the menu looks great!
bhutten
26 Aug 2007 2:32 AM
I.ve just fixed the link: http://www.bsoft.nl/TransMenu.zip
bhutten
19 Dec 2007 3:19 PM
I did a small bug fix. When using Internet Explorer there was a limitation of sub menu's (8), that has been fixed now.
Enjoy!
DonMercer
05 Mar 2008 3:47 PM
Great menu control ... the download and install didn't hurt a bit.
Forums > Users Lounge > Announcements > Free DNN TransMenu implementation ready to use
Skim Question by tlsadler
