Subject: New DNN Creative Support
06 Jun 2007 4:07 PM
I'm pleased to announce we have just employed Joe Craig to help all of the DNN Creative readers in the forum.
This should help to free a bit of my time so that I can focus on creating tutorials and should also mean you get a response to your questions even quicker. - Of course I will still be on hand to offer any advice ;-)
Joe has done everything from skin design, to module development, so site design and operation.  He has also been involved in online communities since the early 1990s on CompuServe, with hosting email discussion lists and forums for the National Association of Investors, and currently with StockCentral.com.
I'm looking forward to working with you Joe, and welcome to the site!
Lee
06 Jun 2007 5:20 PM
Hello!
It's a real pleasure for me to be associated with Lee Sykes and DNN Creative.  I've been an admirer of Lee and his work ever since discovering DNN Creative last summer.  I must say that I never fail to learn several useful things from every issue of DNN Creative.
My role here is to make sure that your questions are answered promptly ... and correctly.
So, ask those questions and put me to the test!
Forums > Users Lounge > Announcements > New DNN Creative Support
Skim Question by tlsadler
