Subject: Community DotNetNuke Search Engine
06 Jan 2006 3:01 AM
I've created a DotNetNuke swicki for the DNN Community.
This is a search engine that is maintained by its users. When a user searches they can promote / demote any of the results, so the more people that use the search tool, the more relevant the search results become.
Check out the search engine here:
http://dotnetnuke-search-swicki.eurekster.com/
Forums > Users Lounge > Announcements > Community DotNetNuke Search Engine
