Subject: $79 DotNetNuke Module and Subscription Competition
21 Aug 2006 8:54 AM
Ventrian Systems yearly module subscription ($35) and a year subscription to DNN Creative ($44) to give away.
Simply login and fill out the survey. You will be automatically entered into the competition. Two winners will be selected at random at the end of the month, one for the Ventrian systems subscription and one for the DNN Creative subscription.
The closing date for the competition is 17:00 GMT on the 19th September 2006.
If you are already a subscriber to DNN Creative you will receive a year extension on your current subscription.
August competition winners
Congratulations to Val Lusis who has won a free subscription to DNN Creative Magazine and Jachin Crawford who the Speerio File Manager Pro Module.
Val achieved a high score of 148,710 on PacMan and Jachin achieved a high score of 797,734 on Tetris.
Forums > Users Lounge > Announcements > $79 DotNetNuke Module and Subscription Competition
Skim Question by tlsadler
Include in Menu - Weird Request by nichord
I have a request from a customer that has put me at odds.  The customer has a lot of child pages to ...
