Subject: DotNetNuke UK User Group Meeting
02 Oct 2008 8:54 AM
the next DNN UK user group meeting for:
Venue:
Guide Post Hotel
Common Road
Low Moor
Bradford
BD12 0ST
http://www.guideposthotel.net/contact/finding.asp
Time: 7-10pm Thursday 16th October
If you wish to join the user group or find a user group in your area, visit this page and login:
http://www.dotnetnuke.com/Community/UserGroups/tabid/1074/Default.aspx
James Burke from deBurca is going to do a presentation on Telerik RadControls that he has recently used in a project.
I am going to OpenForce Europe so I can provide a report on the event / any breaking news for DNN 5 etc.
If any of you are going to OpenForce let me know and we can meet up. It would also be good to have some more of you present some projects you have worked on with DotNetNuke, or anything else you think may be suitable, so if you are interested in doing a presentation to the group let me know.
15 Oct 2008 4:15 AM
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
Forums > Users Lounge > Announcements > DotNetNuke UK User Group Meeting
